camshafts
Guest Freaknasty
Guest Freaknasty
i saw a while back a post for nismo camshafts for the 95 engine. has anybody installed this?? if so, how were the power gains??
thanks for any info
If you're wanting to install new cams, you're going to need to replace your lifters?, and springs, (dunno what else but it has been covered). The lifters and springs develop a certain wear pattern with the cams so that's why you need to replace them.
As for performance, it's one of the best bang for the buck along with headers. You will probably need to bump up the fuel grade too and tune your ECU.
you dont neccessarily have to replae the valve springs so long as they fall within the specs of free hieght and compressed height ...
but the lifters you will definately want to replace if your engine is over 10k thousand miles ...
keep in mind that the race cams signifigantly increase the idle, past the point where you could get your rig to pass emmissions if that is required in your area ...
