suzonka Posted August 22, 2009 Share Posted August 22, 2009 Has any one ever locked there chip type key in there pathfinder in there pocket book or ignition on or off condition? and then used your extra spare remote the one you keep at home to open the door? Will it work or will the chip key inside the car stop your spare remote from opening the door? just want o be prepaired for the unexspected ,to me its a bunch of crap to make the insurance companys rich [click click ,churp churp,flash flash ] wooopeeedo a 300.00 bill to get towed to the dealer for a lock out$$$$ Link to comment Share on other sites More sharing options...
02silverpathy Posted August 22, 2009 Share Posted August 22, 2009 It should work fine, the chip is only for starting the engine. If you get a remote start installed you most likely will have to give a chip key up for installation...guess where it goes? Inside the car under the dash with the alarm, so that the alarm can "verify" with the OEM anti-theft that the car can be started. Link to comment Share on other sites More sharing options...
suzonka Posted September 1, 2009 Author Share Posted September 1, 2009 It should work fine, the chip is only for starting the engine. If you get a remote start installed you most likely will have to give a chip key up for installation...guess where it goes? Inside the car under the dash with the alarm, so that the alarm can "verify" with the OEM anti-theft that the car can be started. THANKS FOR THE INFORMATION Link to comment Share on other sites More sharing options...
