OldSlowReliable Posted June 29, 2009 Share Posted June 29, 2009 (edited) figured it out! Edited June 29, 2009 by OldSlowReliable Link to comment Share on other sites More sharing options...
Precise1 Posted June 29, 2009 Share Posted June 29, 2009 Someone else might not have though... B Link to comment Share on other sites More sharing options...
OldSlowReliable Posted June 29, 2009 Author Share Posted June 29, 2009 Lol....ok, here ya go Brake light and ABS light were coming on when I accelerated around corners, or braked hard around corners....then would go off shortly after....check my brake fluid, and it was barely above minimum, so I got out my DOT 3 brake fluid, and filled it up to MAX......gonna test it out on my way to trumpet lessons and see if it worked! Link to comment Share on other sites More sharing options...
Astroc2002 Posted June 30, 2009 Share Posted June 30, 2009 Lol....ok, here ya go Brake light and ABS light were coming on when I accelerated around corners, or braked hard around corners....then would go off shortly after....check my brake fluid, and it was barely above minimum, so I got out my DOT 3 brake fluid, and filled it up to MAX......gonna test it out on my way to trumpet lessons and see if it worked! Glad to here someone else is experience this with their ABS/E-Brake Light when going through corners because I thought I was going crazy. Strange thing is that it only happens when I'm going through right turns. Weird. Link to comment Share on other sites More sharing options...
OldSlowReliable Posted June 30, 2009 Author Share Posted June 30, 2009 Glad to here someone else is experience this with their ABS/E-Brake Light when going through corners because I thought I was going crazy. Strange thing is that it only happens when I'm going through right turns. Weird. My guess, is that the sensor is located somewhere on the right side, and when making a right turn, all the fluid goes to the left, making the sensor think its empty Link to comment Share on other sites More sharing options...
Astroc2002 Posted July 1, 2009 Share Posted July 1, 2009 My guess, is that the sensor is located somewhere on the right side, and when making a right turn, all the fluid goes to the left, making the sensor think its empty Hmm... That's still weird. oh well as long as my truck still stops and goes I guess it'll be alright until next week when I have the oil changed in it. Link to comment Share on other sites More sharing options...
OldSlowReliable Posted July 3, 2009 Author Share Posted July 3, 2009 Hmm... That's still weird. oh well as long as my truck still stops and goes I guess it'll be alright until next week when I have the oil changed in it. They didn't check mine when I had my oil changed, and I had a bottle of brake fluid sittin around, and a new small bottle is only like a buck or two @ walmart.....Pretty easy to do, and keeps me from havin to worry bout it... Link to comment Share on other sites More sharing options...
Kn0xville Posted July 5, 2009 Share Posted July 5, 2009 now to find your leaky caliper Link to comment Share on other sites More sharing options...
