Guest '95pathyXE Posted August 21, 2004 Share Posted August 21, 2004 Hey, i was just wonderin if any one has had any problems with the alarm in their Pathfinder. The one in my 95 is really touchy, all i have to do is lean on the side of it and the alarm goes off. Link to comment Share on other sites More sharing options...
kbreitwieser Posted August 22, 2004 Share Posted August 22, 2004 I think there is a sensitivity setting under the drivers seat, you can change it to low if your alarm is too touchy, correct me if I'm wrong guys..... Link to comment Share on other sites More sharing options...
ChromoTech Posted August 24, 2004 Share Posted August 24, 2004 my alarm is craaaap you could hit it and it wont go off and i have the sensitivity turned up on high Link to comment Share on other sites More sharing options...
Seattle_Al Posted August 24, 2004 Share Posted August 24, 2004 The only warrantee work we had done on our '95 was replacing the alarm brain. 9 years later, no problems. As already mentioned, it's under the driver's seat, and has a sensitivity switch... Link to comment Share on other sites More sharing options...
BigMike Posted August 24, 2004 Share Posted August 24, 2004 my alarm is craaaap you could hit it and it wont go offand i have the sensitivity turned up on high same here, you could have it roll down a cliff of hit it going 50 and it wont go off but if you open the door with the alarm on, watch out. ive got a 130 decible air horn hooked up to it and man is it loud. i know exactly when it goes off cause i can hear it across the nieghbor hood. keeps thieves away every one knows whos rig it is Link to comment Share on other sites More sharing options...
