Wierd noise after engine tune up
xcapepr
I just finished replacing the timing belt in my 00 LE Pathy thanks to the shop manuals I found in this board. But now the engine has a rev dependent zooming sound. I think I hay have over tightened the timing belt tensioner or its just that the tensioner needs to loosen up a bit.
I have only driven it for around 2 to 3 minutes around the block to check for leaks and the noise remained. I'm thinking about giving it a couple days worth of use before tearing it up again and re-checking if it is in fact over tightened (aside fro the time I need to finish it and don't have). I followed the instructions in the shop manual as for the amount of tension needed.
Any suggestions appreciated!
