Guest bryan89 Posted August 9, 2004 Share Posted August 9, 2004 anybody with the trailmaster suspension lift ......listen up as you all know, the spindle drop bracket requires that you get new wheels because the stock ones have too much backspacing and the sidewall of the tire rubs the upper a-arm. QUESTION... what backspacing rim do i need to run a 12.5 inch wide tire? i want 33x12.50 bfg muds. after calling them, they actually reccomend a 10 inch wide wheel to get the maximum foot print out of that tire. so that gives me a sidewall bulge of 1.25 inch on either side (12.5 tires - 10 inch rim = 2.5 bulge divided by two sides of wheel= 1.25 bullge) does that mean i need a 3.25 backspacing wheel to stay within the tire and wheel combination width of 4.5 inches from the mounting plate to the sidewall bulge? what do you guys run? :help: Link to comment Share on other sites More sharing options...
MatterHorn Posted August 10, 2004 Share Posted August 10, 2004 yeah you should run at a maximum 3.25 of backspacing ... and that would actually work for a 8 inch wide rim too ... I run a 15x8 rim ... and I only have 3.75 inches of backspacing ... it does occasionally rub the UCA, but I have ground quite a bit of material off and smoothed it out to be less abrasive ... the other alternative is to run some wheel adapters, which I have, but am waiting to get some opened ended lug nuts that fit the wheel hub ... Link to comment Share on other sites More sharing options...
Guest bryan89 Posted August 10, 2004 Share Posted August 10, 2004 you ground down the a-arm? Link to comment Share on other sites More sharing options...
MatterHorn Posted August 10, 2004 Share Posted August 10, 2004 yep ... the outer most edge of it (basically the part closest to the tire) ... I also ground a bit of the balljoint too ... Link to comment Share on other sites More sharing options...
