scottha16 Posted August 1, 2004 Share Posted August 1, 2004 I just got an 89 XE-V6 2wd Pathfinder, and i was wondering if there was anything i can to it to make it more geared for offroad. Iv already lifted the body 3 inches and plan to get some larger tires but anything engine wise or performance wise? Link to comment Share on other sites More sharing options...
Guest NissanD21man Posted August 5, 2004 Share Posted August 5, 2004 Where are you from scottha16? I thought they didn't start making 2wd 'finders until the mid '90s (in the US). Is your truck a 2 door? If you don't have a limited-slip differential, adding one would be a big help. Then at least if you got one wheel into some muck, you would have 2wd instead of 1wd The limited slips can be identified by an orange sticker on the back of the diff that says "LSD" My one musician/hippie friend got a real kick out of the sticker on mine, hehe. "No Budd, don't taste the gear oil, it stands for Limited Slip Differential." Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 6, 2004 Share Posted August 6, 2004 A rear diff locker will help you infinitely more than anything else in your case. Then the bigger tires, body lift and the driver will make more of a difference than anything. A K&N filter, good exhaust and properly maintained engine will keep you rolling with little to wish for unless you want more, in which case you'd better be looking a bit harder. Link to comment Share on other sites More sharing options...
scottha16 Posted August 6, 2004 Author Share Posted August 6, 2004 Where are you from scottha16? I thought they didn't start making 2wd 'finders until the mid '90s (in the US). Is your truck a 2 door? If you don't have a limited-slip differential, adding one would be a big help. Then at least if you got one wheel into some muck, you would have 2wd instead of 1wd The limited slips can be identified by an orange sticker on the back of the diff that says "LSD" My one musician/hippie friend got a real kick out of the sticker on mine, hehe. "No Budd, don't taste the gear oil, it stands for Limited Slip Differential." Im from Augusta Georgia, and im 17. My mom got me the Pathfinder for my 17th birthday after seeing this website. Yes its a 2 door, and after a little researching my pathy is actually the first 2wd they made. Is limited slip differential same thing as rear differential lock? I know my friends tacoma has rear diff lock and its save his hiney alot of times. And if so is there a kit I could order? I also just ordered a K&N to replace my current filter, and im gonna get rid of these stock tires. Link to comment Share on other sites More sharing options...
jason Posted August 27, 2004 Share Posted August 27, 2004 This might help: http://www.nissanpathfinders.net/forum/index.php?showtopic=858&hl= And the locker: http://4wheelparts.com/4wp/products/produc...vetrain&man=ARB Link to comment Share on other sites More sharing options...
miked18235 Posted August 29, 2004 Share Posted August 29, 2004 i'll sell you a 4wd Pathfinder for 500 bucks you can take the whole front suspension, rear, transfer case and driveshafts put it on yours and you got 4wd Link to comment Share on other sites More sharing options...
