Fuses Keep blowing
murbike
01 Path.
Front outlet (dash) doesn't work at all.
Middle outlet (armrest) works, but when I plug in the phone, blows fuse.
Back outlet (right rear (why?)) same as middle...
I'm thinking there's a short, and I'm hoping it's in the front one and I'm hoping that just replacing it will fix the issue. P...
Has anyone seen/heard of this before?
sounds like either your phone is drawing too much current (doubtful)
or your charger is shorting
is there something else you can try in your outlets?
i tend to think if its a wiring short with the car, the fuse would blow as soon as you put it in - no applicance needed on the end of your outlet to make it short
Have a look at your phone charger. See if it says anywhere how much current (Amps) it draws, as SW asks above.
Then take a look at the Amps number on the fuses you're trying to use.
Have a look at the fuse diagram, if you have one.
The charger may draw too much, OR you may have the wrong size fuse in there.
I've blown a 5Amp fuse before and replaced it with another 5Amp and blown that one and done this three times before I discovered that the original fuse should have been 10Amp... -thnkboutit-
If it were a short in the truck, it would probably be blown all the time.
SW is right. Try plugging something else in.
Just don't use a fuse rated higher than it should be, for that circuit.
And whatever you do, don't bridge across the fuse holder with anything other than a fuse. Unless you want to claim on your fire insurance. sly
Hope you have a win.. ;)
