transfer case problem
Daggym
Im not sure if this has been covered but i couldnt find anything in the search. wat does it mean when i try to engage 4LOW and a big red A.T.P appears? i did do a 2 inch body lift i know you might have to change the stick, but it sems like its going into 4LOW but wont engage at all.
Thanks
You're probably only getting the transfer case into neutral. You'll either have to swap the shifter, bend your existing one, or notch the floor to get it into 4LO.
