Manual transmission issue...is it related to TSB
azscott
My 87 has a manual transmission.......now I do not have any wine as related to the TSB in the sticky notes above but.......it does like to pop out of third gear when you let off the gas. As long as you are not coasting in 3rd it is fine.....so under acceleration no problem.
I did read the entire TSB thread above and so was curious as to what may be causing this. I did not worry about it at first as it is not an issue and...I don't have any whine.
I know the previous owner took it to Nissan regularly for service and fluid changes....he had the entire drivetrain fluids changed a few years ago..although I don't see what type they used in the service receipt.
Anyway...I will change the transmission fluid per ther TSB spec but any thoughts on what causes it to opo out of 3rd while decelerating.
Scott
Edited by azscott
