p1145 code help
ok i got a p1145 code that appears as soon as i turn on the key and when i searched the net i get that its a vtc sensor but i dont know what side. advance said that it is a mass air flow, so know i dont know what to think. if the p1145 is a vtc does someone know what side that is on driver or passenger. also does anyone know what i would have to do to check to see if the vtc sensor is bad or good
thanks
ashton
Your 2001 FSM says on Page EC-484 that it's the Left Side. I've quoted the page below. You can download your FSM HERE
DTC P1140 (RIGHT, -B1), P1145 (LEFT, -B2) INTAKE VALVE TIMING CONTROL
POSITION SENSOR (CIRCUIT
Component Description
NAEC0705
Intake valve advance unit position sensors are located in the front
cylinder heads in both right/left banks.
This sensor uses a Hall IC (element).
The cam position is determined by the intake primary cam sprocket
concave (in three places). The ECM provides feedback to the
intake valve timing control for appropriate target valve open-close
timing according to drive conditions based on detected cam position.
CONSULT-II Reference Value in Data Monitor
Mode
NAEC0706
Specification data are reference values.
MONITOR ITEM CONDITION SPECIFICATION
INT/V TIM (B1)
INT/V TIM (B2)
I Engine: After warming up
I Shift lever “N”
I Quickly depressed accelerator
pedal
I No-load
Idle 0° CA
2,000 rpm Approximately 12 - 18° CA
1145 is driver's side VTC/solenoid. 1140 is passenger side. I just went through this. If you replace the sensor and are still pulling the same code, you will need to clean or replace your cam solenoid.
Assuming this is a 3.5? Not sure if the VQ33 uses the same codes/sensors.
If it has the 3.5 its a 2001.5. Also if you look at the metal plate on the firewall where it has all the specs it will say in what month it was made, and it might also say that on the plate on the drivers side door jam but im not sure about that one.
Edited by csutke
