Cuong Nguyen Posted May 14, 2008 Share Posted May 14, 2008 i was wondering if I could fit the old square-ish looking front bumper off a hardbody or pathfinder on my 93 Pathfinder. I need a front bumper to pass inspections....hardmounted turn signals and license plate. Link to comment Share on other sites More sharing options...
GhostPath Posted May 14, 2008 Share Posted May 14, 2008 What, the "Jeep club" didn't know? Yes, it will swap on. However, you may have to swap the bumper brackets for it to work. Link to comment Share on other sites More sharing options...
LandShark Posted May 14, 2008 Share Posted May 14, 2008 Cuong I'm actually looking at the same thing right now to mount my new TJM. What I'm thinking now is order a pair of these: Cut them down the middle, and weld them to the half of my current brackets that mount to the frame. Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted May 17, 2008 Author Share Posted May 17, 2008 I found out today that the pre 93 bumper brackets don't work for post 92 models. The top bolt hole does not line up with the hole on the frame mount. Link to comment Share on other sites More sharing options...
GhostPath Posted May 17, 2008 Share Posted May 17, 2008 Well, you can have (for the cost of shipping) my slightly bent front one to see if it lines up on your frame. It should, as I was playing around with swapping parts off of a 93 for a while. Link to comment Share on other sites More sharing options...
nunya Posted May 17, 2008 Share Posted May 17, 2008 as long as you have the correct brackets for the year bumper you are able to flip them back and fourth either way, i would assume the same goes for the rear as well Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted May 17, 2008 Author Share Posted May 17, 2008 Thank for the offer Ghostpath but I just needed a bumper to passed inspection. I just used the bottom holes and bolted up the bumper. Link to comment Share on other sites More sharing options...
