RP94Pathy Posted April 4, 2008 Share Posted April 4, 2008 I have a 94 pathfinder with a stuck rear passenger side door. Won't open form inside or outside handles, lock seems to function properly (although hard to tell obviously). Any ideas on how to get the door open? I'm not able to remove the inside panel while the door is closed. Help!! Link to comment Share on other sites More sharing options...
jj big shoe Posted April 4, 2008 Share Posted April 4, 2008 Unless you can take out the seat and gain access to remove the door panel you're prolly going to have to "slim jim" it open. Once you do you can replace the broken clips on the linkage rods for the handle. Then again mine's a two door so what do I know. Link to comment Share on other sites More sharing options...
dagwoodzz Posted April 5, 2008 Share Posted April 5, 2008 http://npora.ipbhost.com//index.php?s=&...st&p=131814 Here's sum pics of the front door. Hope it helps Link to comment Share on other sites More sharing options...
ninoj Posted September 9, 2008 Share Posted September 9, 2008 http://npora.ipbhost.com//index.php?s=&...st&p=131814 Here's sum pics of the front door. Hope it helps Was the door ever fixed? I have have the same problem. Link to comment Share on other sites More sharing options...
91PathSE Posted September 9, 2008 Share Posted September 9, 2008 rear door...who cares Link to comment Share on other sites More sharing options...
BrianD Posted October 17, 2015 Share Posted October 17, 2015 My 98 pathy has the same prolm. The outside rear passenger door handle is "flopping in the wind" and the interior handle seems normal. I took the inner handle out of the panel as much as possible and the rods are still connected. WTF? It won't open and I can't remove the inner panel when the door is closed. How DOO I get this open so I can fix it? Any help appreciated. I load a lot of stuff in an out so it wud be just swell to have it werking again. Link to comment Share on other sites More sharing options...
SkiBumBrian Posted October 17, 2015 Share Posted October 17, 2015 Nice revival of a 7 year old thread ! Like was said it will probably take someone proficient with a slim Jim or remove back seat for access. Link to comment Share on other sites More sharing options...
BrianD Posted October 17, 2015 Share Posted October 17, 2015 Thanx Old Timer but U can't remove the inner door panel when the door is closed - it's up against the steel door frame and rubber gasket. So removing the seat does nuthin'. Buuut..Anyone ever call Nissan about this? I will luk into the slim Jim - Cheers Link to comment Share on other sites More sharing options...
SpecialWarr Posted November 20, 2015 Share Posted November 20, 2015 I think the Slim Jim is the only answer on that one. I can't see any other way to get to the internals without wrecking the door card. Link to comment Share on other sites More sharing options...
dagwoodzz Posted July 21, 2016 Share Posted July 21, 2016 (edited) Tried to repost pics but failed miserably Edited July 21, 2016 by dagwoodzz Link to comment Share on other sites More sharing options...
