timing belt tensioner spring
amyj1969
ok. tighten down where spring has pressure and belt wants to walk off. if you leave spring with no tension but still touches stud, than belt stays on. Should it have no tension on it but still touching stud? Like I said when you put little tension on the spring, the tbelt walks off the pulley. never worked on a pathy before and after hearing the horror stories of a broken belt, want to make sure
