abomb1 Posted June 24, 2004 Share Posted June 24, 2004 I would like to install my cone filter tonight, but want to make sure I have all the parts first. I got the filter off ebay with an adaptor plate for an Altima (from what I've read that is the one to use, just need to drill out the holes a little). What size bolts do I need to attach the adaptor to the MAFS? Do I need to buy some gasket material to cut out for between the MAFS and the adaptor? I will use the OEM airbox mounts to secure the MAFS so that the filter does not flop around. Anything else I am missing? Link to comment Share on other sites More sharing options...
Guest drunken_rice Posted June 24, 2004 Share Posted June 24, 2004 since u didn't list the year of ur car its kinda hard to help u correctly but if it falls within the correct year i would suggest you check here http://www.jimbennett.net/k__n_installation.htm u'll find all u need to know.... good luck i did it on my 90 pathy and it works great.... Link to comment Share on other sites More sharing options...
abomb1 Posted June 24, 2004 Author Share Posted June 24, 2004 Yep, read that installation, but I got an adaptor plate with my filter that I would like to use instead of pulling that gold ring out of the airbox. I know others have done it this way, just want to make sure I'm not missing anything and that I buy the right hardware for bolting the adaptor to the MAFS. My Pathfinder is a 94. Link to comment Share on other sites More sharing options...
