95 Pathy.... is the TPS serviceable?
Splinter
I am trying to eliminate a hesitation problem that I have only when I am doing 85-95 kph. It doesn't do it under load like a bad wire, it only does it while I am cruising down the road.
Is the TPS a throw away or can I take it apart and clean it?
Thanks
Chris
Thanks guys.
Now second question..... when you say that it's testable does that mean that I can test it for a bad spot in it's range of motion? Or is it just testable to see if it works?
Thanks
Thanks guys.
Thanks
You can test it for a bad spot in the range of motion... BUT.
Sometimes a bad one will test good because you didn't hit *just* the right spot while testing.
The TPS is considered to be a consumable/wear part anyway. Eventually they wear out; 13 years is a decent run for one. I'd just replace it. Dealership wants less than $100 for it. Alternately, you could get the TPS (used) from a lower-mileage truck that died from unrelated reasons - all the WD21 MPFI V6 trucks use the same TPS.
Correction: All automatic trucks use the same TPS, all manual trucks use the same TPS. You cannot use a manual TPS on an automatic truck.
Edited by GhostPath
The TPS is considered to be a consumable/wear part anyway. Eventually they wear out; 13 years is a nice long run for one.
Thanks GhostPath. I appreciate the info. When I test it am I using my OHM meter to test for resistance? Do you think that a bad TPS would cause the Pathy to hesitate while I am keeping a constant speed? It doesn't do it when I am accelerating, just at one speed.
