jpawela Posted November 11, 2007 Share Posted November 11, 2007 Hope this isn't a repost. I've search, but nothing comparable came up. Well, here goes: It looks like I will be towing my sister's car to my grandparents place. My Pathy is stock with no external auto tranny cooler or any other trick mods (except the tow hitch and wiring). It has 94K miles on the clock and as far as I know, the auto tranny is original and in good working order with clean fluid. The LSD diff also had a recent transplant of fluid. Do you guys think it will be safe to tow this far? Or to tow at all? I've never done it before with this truck. I've heard the our trannys suffer a bit without any cooling aide. Here's more details: It will be all freeway travel where I probably will travel around 65-70mph Only three hills to contend with The outside temp is a steady 68-73ºF The car being towed weighs about 2400lbs Only other weight in the truck is my 80lb Germen Shepard Appreciate any input...thanks Link to comment Share on other sites More sharing options...
Mookie Posted November 11, 2007 Share Posted November 11, 2007 Are you flat towing, dolly, or trailer? You can get the Pathy to tow, but it's always the stopping, or worse, the pushing that you may experience. Link to comment Share on other sites More sharing options...
Xmas Posted November 11, 2007 Share Posted November 11, 2007 Nah, you should be fine. If you can, get one of the Uhaul car dollys that you can put the whole car onto it and make sure the trailer has surge brakes. Also, ALSO - keep your engine out of OD. Make sure the OD button is OFF at all times! Other then that, take it easy and drive safe! PS - owned lots of boats, so I know about towing and what mistakes I done Link to comment Share on other sites More sharing options...
jpawela Posted November 12, 2007 Author Share Posted November 12, 2007 Thanks for the replies. I was planning on renting just a dolly from Uhaul. I was also warned by others to not use O/D as it would heat the hell up. I didn't know that. Thanks again! Link to comment Share on other sites More sharing options...
jpawela Posted November 14, 2007 Author Share Posted November 14, 2007 Well, the trip went smooth with no drama. I was surprised how well it handled the tow. The gas was just about what i expected: 11mpg. Thanks again for the replies/suggestions. Done with this tread! Link to comment Share on other sites More sharing options...
