Am Imissing something
dragonfly
OK this is the list
1992 WD21 XE pathy grey with all the usual issues in the lists
Ball joints upper lower RH / LH
OME shocks front and rear
OME springs
Warn hubs with bearing grease seals
Calmini HD Steering Kit
15x8 steel rims with 31x10.5 BF Goodrich All terrains Awaiting Install.
I have purchased the socket for the hub/ wheel bearing nut
Soaked the nuts bolts etc in Aerokroil three times.
I have the grease Mobil One synthetic for the bearings.
I have searched all the forum topics and have looked through the Haynes manual religiously
Do I have to pull the whole knuckle to do the bearings. Is this the easy way??
I am doing the ball joints etc.
Just looking for some tips. Not help
Problems etc.
Pullers??
I currently work for a Float plane overhaul shop so I have many things at my disposal.
Lots and lots of really big hammers.
Thanks
And it begins
Randy
Nope...don't need to pull the knuckle to do the bearings. Undo the upper ball joints, disassemble the hubs, and you'll be into the wheel bearings. You can typically get the CV's pulled back enough to get the inner races out without having to pull out the whole knuckle.
