Bret01 Posted October 22, 2007 Share Posted October 22, 2007 My wife drives an '01 Pathfinder SE 2WD that has an automatic transmission. I changed the transmission fluid and filter at 45k miles, 75k miles, and 105k miles. At about 104k miles, my wife told me that the engine was reving real high before it would shift when it was cold. She also said that it would sometimes make a rumbling noise when she was stopped at an intersection. I drove it and sure enough, while the engine/transmission was cold, the transmission would stay in first gear too long. It would then shift which felt kind of hard but was probably just because the rpms were so high. I also heard the rumbling noise that she described. Since I was just short of 105k, I decided to change the transmission fluid and replace the filter. The fluid that came out looked good. It was a little dirty, but you could still see through it. I dropped the pan and found that the magnet had a bunch of metal around it, significantly more than I remember it having previously. I also found some other metal in the pan which wouldn't stick to the magnet. I assume this is aluminum. In the filter strainer I could also see some metal shavings. I put everything back together and replaced the fluid with the same amount that was drained out. Unfortunately, the problems didn't go away. Fast forward about another 1k miles and it's still doing the same things. In addition, I drove it once from cold and it kept stalling out at an intersection. Once it got warm, the problem went away. I've checked the fluid level with the vehicle running and it is just above the full mark. I drove it to a local transmission shop. The owner drove it once and said he didn't have any problems. He then drove it a couple of days later and said that it kept stalling out on him. He said that based on that and the aluminum in the pan I need to have the transmission rebuilt. He quoted me $2350 to to do it. His warranty is 18 months or 18k miles. That seems like a very short warranty for such a big chunk of money, so I've started doing research on places that rebuild transmission which offer longer warranties. I've found a couple, but my confidence level isn't high that I definitely need a rebuilt transmission. Could something else simpler be going on? 105k seems early for a Nissan Pathfinder transmission to go out, especially one that's been properly maintained. Link to comment Share on other sites More sharing options...
Bret01 Posted October 31, 2007 Author Share Posted October 31, 2007 Anyone? Link to comment Share on other sites More sharing options...
harv Posted November 8, 2007 Share Posted November 8, 2007 Anyone? heres some info i found Automatic transmission: Automatic transmission may flare (seem to drop out of gear) between shifts requiring replacement of the transmission control module. (2001) Engine noise: A rumbling, bearinglike noise from the transfer case is corrected by replacing the companion flange with a redesigned component. (2001) hope this helps mate Link to comment Share on other sites More sharing options...
Bret Posted November 8, 2007 Share Posted November 8, 2007 Thanks. It doesn't seem to be dropping out of gear. I took it to another Nissan stealership. They also said that it needs a new transmission. They only want $3200+tax and they'll give it a great 12month/12k mile warranty. I said no thanks. We've had it at home for a few days now. The only time we seem to have trouble is when we just start out. It just doesn't want to shift out of first gear for a minute or two. It will, but the engine revs high before it does. After it's warm, it drives perfectly normal. Link to comment Share on other sites More sharing options...
