Pinhole In Headlamp
dagwoodzz
The driverside headlamp has a pinhole from a rock 1/16" diameter. It's causing my bulb to burnout every 6months +/-. (probably moisture related more than time). Are there any products (Krazyglue?) that can seal the hole and withstand heat for that type application. A new headlamp is not that expensive, but if I could stick some $2 secret goo in there it would make me happier. Louisiana Inspections aren't tough so that's not a factor.
Headlamp $33??
