lyzic Posted August 4, 2007 Share Posted August 4, 2007 Wondering if this is normal, or if my throttle bodies need cleaning, or if it is something else? Basically, whenever I hit the gas pedal when the pathy is in cruise control, there is a certain amount of resistance before the pedal starts moving. It's a 2000 R50 w/ about 160k on the clock Cheers! Link to comment Share on other sites More sharing options...
denisb Posted August 4, 2007 Share Posted August 4, 2007 Not sure if the throttle body had the same issue as the WD-21s, but it could be your problem. Is it just when you use your cruise? You should notice some sticking even without the cruise, if this is your issue. On a side note, you can always try to clean it and see. It's not that big of a job. Denis Link to comment Share on other sites More sharing options...
