Sticky Pedal After Cruise Control
lyzic
Wondering if this is normal, or if my throttle bodies need cleaning, or if it is something else?
Basically, whenever I hit the gas pedal when the pathy is in cruise control, there is a certain amount of resistance before the pedal starts moving. It's a 2000 R50 w/ about 160k on the clock
Cheers!
Not sure if the throttle body had the same issue as the WD-21s, but it could be your problem. Is it just when you use your cruise? You should notice some sticking even without the cruise, if this is your issue.
On a side note, you can always try to clean it and see. It's not that big of a job.
Denis
