Is There More Spacer Interest?
tmorgan4
I thought about the spring becoming unseated but that can be resolved by adding a clamp to the mounting plates for the spring. As for leveling out the ride, the extender should do the same as a spacer, instead of putting an inch on top of the strut assembley you put it inside, which should give you the same outcome. I dont know if that makes sense.
I thought about this same idea a while back. Good to see someone else doing it.
The strut extension isn't going to give you any lift. It's just going to change how far the strut is extended at ride height.
Like others have said though, make sure to put some form of limit strap on there since however long the strut extension is = that much in added downward travel.
