dsb Posted July 4, 2007 Share Posted July 4, 2007 hi, was just contemplating doing a swap , taking a 3L navara diesel n man box and droping it in to a 1990 diesel terrano ? has any one done this? what would be involved? intersted cos i can get half cuts from japan so i would have all the pices? Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted July 4, 2007 Share Posted July 4, 2007 hi,was just contemplating doing a swap , taking a 3L navara diesel n man box and droping it in to a 1990 diesel terrano ? has any one done this? what would be involved? intersted cos i can get half cuts from japan so i would have all the pices? Half cuts ay? I'd be interested in the late model dash '95 '96. I want to update my old one for a new look. As for the engine upgrade.... Put a 3.8ltr V6 in it. To do that you'd need a body lift. 2" will do it and it will be the same as a stock standard 4x4 Navara, and then up size you tyres. The Nissan motors are gutless and not very fuel efficient. The gearing in them is too low. You are very limited as to what mods you can do given that you are in QLD. If the engineers in QLD have the same info re a WD21 Pathfinder as the guys down south, you will not have an issue with the body lift. I got a 3" passed. They use the Navara specs on the pathy and a 3" lift looks like a 1" lift. Good stuff. Link to comment Share on other sites More sharing options...
