SteeevO Posted April 1, 2007 Share Posted April 1, 2007 (edited) You can read about what has been going on on N4W Here: N4W T-Case Discussion But basically this is what this boils down to... the first adapter goint to come off the machine in probably 2 weeks. but we are still trying to figure out the length of the adapter needed to make everyone happy. so basically we need to decide if the majority of the people that are interested in this adapter would rather run a short adapter that puts the front output at stock position but requires a Center Support Bearing & 2 Piece Drive Shaft for the rear DS. OR have an adapter that puts the rear output at the stock position to have a one piece rear DS and pushes the front output towards the rear. but requires a hole in the floor to make room for the new t-case that causes your floor to no longer support seats and requires you to bolt seats to a cage that you may not have. Everyone please respond to this as the first complete adapter is due to come off the machine in probably 2 weeks... we need to figure this out ASAP. Edited April 1, 2007 by SteeevO Link to comment Share on other sites More sharing options...
88_Pathy Posted April 1, 2007 Share Posted April 1, 2007 What t-case will you be able to run with the adapter. Also why a 2 piece in the rear. I know I wouldn't want to cut the floor out a lot. Link to comment Share on other sites More sharing options...
89_trailboss Posted April 1, 2007 Share Posted April 1, 2007 I would rather have the long rear, stock front drive shaft lenght. this would be great cause if you were to do a doubler the rear would be abit shorter. Link to comment Share on other sites More sharing options...
SteeevO Posted April 18, 2007 Author Share Posted April 18, 2007 Design is done. The adapter was stretched out to put t-case rear output at about the stock position. which also moved the front output back 3D CAD images will be avaliable shortly. Please E-mail me or PM me if you are seriously interested. We need to make atleast 5 on this first round to keep the cost down. Link to comment Share on other sites More sharing options...
