jgt Posted March 12, 2007 Share Posted March 12, 2007 while installing a new cd deck, I think I blew the fuse to the 12v constant (yellow wire). Called crutchfield and they helped my troubleshoot it (works when we hot-wire it to switched red wire) but no power when when wired to yellow. He said there should be 2 10amp radio fuses. I only see 1 10amp fuse for the radio. What am I not seeing? This is for a 92 XE w/ no stock amp. What are the large relays above the fuses in the fuse box? Thanks to anyone who can tell me where the fuse it is that I blew. - jules Link to comment Share on other sites More sharing options...
jgt Posted March 12, 2007 Author Share Posted March 12, 2007 figured it out, looked in the elect. part of the service manual and saw the int. lights were 'battery'. So that was the 10amp fuse that I took out to replace the blown radio 10amp fuse. I suppose that makes sense that the int dome lights have a constant power, shheesh. Link to comment Share on other sites More sharing options...
89_trailboss Posted March 12, 2007 Share Posted March 12, 2007 FYI, all WD21's have factory amps. what type of deck did you install? if its an Alpine Vpower, run a 12 or 10 gauge wire strait from the batt. those damn HU are power hunger. Link to comment Share on other sites More sharing options...
