TD27 service manual
Guest r4rosal
Guest r4rosal
Hi everyone,
Anyone out there kind enough to help me, please I need a service manual for the TD27 diesel engine.
I need to know the important adjustments like valve clearances, etc.
I can't find a reliable shop to tune up my pathy so I want to do the maintenance by myself.
Please help because I think my engine is really getting out of shape.
thanks! :help: :help:
Service manuals are $$$$$$$$$$ to buy!!!
I don't think any one on this site has one, as you are one of four of us that have the TD27t engines.
Ask any Q's you like, i have done alot of work on mine so hopefully i can pass that on to you!!
Valve clearences i can get.
BUT, mine were noisy when i got the vehicle, i went to my reliable mechanic, asked about what sort of system was used, eg shim and bucket etc.
The answer i got was that the rockers and rocker shafts wear really badly and in most cases are not worth playing with.
So what i ended getting done was getting the rocker shaft reconditioned and new rockers. Very cheap. So basically if its sounding noisy, then there is a very limited amount of adjusting you can do.
I'm pretty sure the clearences are on a sticker in my engine bay, i'll check for you.
If you ring your local Nissan dealer they will also supply them for you.
Anything else ask away!!!
Cheers,
Pete.
