TK1 mod drawings
Pavelow Leaks
I've been looking everywhere, and I've found the directions and parts listings to do the TK1 mod, but everywhere there was a picture or diagram a little red x resides. So if anyone has the drawings or pics and would be kind enough to post them up for me I'd appreciate it. :bow: I'm gonna go this route because A. my funds are limited, and B. I have a friend that will do the machine work for beer....so it works out for me. He's also making me the idler arm brace, and reinforcing both the idler arm and pitman arm.
I'm pretty sure we can do it without the drawings, because the instructions are pretty specific, but it'd be nice.
Torch off the old ends(ball joints), and weld the new tubing/casing on each side, then press in the two bearings on each side.
From what I've read so far you'll pretty much HAVE to have a machine shop do the bearings if you want them done right the first time. :aok:
PS: Don't press the bearing in first and then weld it to the CL. Not unless you like the smell. :beer:
