hmrepairs Posted January 14, 2007 Share Posted January 14, 2007 Hope one of you can help me. I'm re-building the trans in my 1993, and am needing a more detailed schematic of the valve body assembly. This trans has been disassemble before, and I have found another item that was put back together incorrectly, so I don't want to assume that anything in the valve body is correct. Would really like a detailed schematic to use and start from scratch. I bought a manual which gives pretty good detail on everything but the valve body. Any help would be great. Thanks !! Link to comment Share on other sites More sharing options...
unccpathfinder Posted January 14, 2007 Share Posted January 14, 2007 check ure PMs...I would think the trannys from 93 and 94 are the same if so my PM will help out... Link to comment Share on other sites More sharing options...
hmrepairs Posted January 14, 2007 Author Share Posted January 14, 2007 I think this will work, thanks so much. Link to comment Share on other sites More sharing options...
unccpathfinder Posted January 14, 2007 Share Posted January 14, 2007 notta problem good luck Link to comment Share on other sites More sharing options...
