Skyjacker shocks
Guest SuperSon
Guest SuperSon
Good morning all!
Has anyone seen this new shocks from skyjacker. Looks like rancho shocks probably is a rancho shocks and skyjacker just stamped their name on it.
It also claims that it gives a 2-4 lift
Application:
Vehicle: 86.5-93 Nissan Pathfinder/Terrano 4x4/2x4
Lift Amount: Front: 2" to "4" Rear 2" to "4"
Notes:
Hydro 7000 Features
+ Hydraulic action
+ Multi-stage velocity sensitive valving
+ Twin tube construction
+ Over-sized piston head
+ 14 mm piston rod
Backed by Skyjacker limited lifetime warranty!!!
Notes:
The Shocks for your application may differ from the shocks pictured. By purchasing this item you will receive the correct shocks for the application stated above.
All Skyjacker Shocks come with RED shock boots.
Different colored boots are available for only $10 for all 4.
With no additional shipping. Please contact us for details 1-877-274-9362
Shocks can be purchased individually as well. Please contact us for details 1-877-274-9362
NITRO UPGRADE only $20 for all 4 !!
(with no additional shipping)
If your vehicle sees more off-road than on, or carries heavy loads more often than not, These stiffer NITROGEN shocks are for you! These shocks are more responsive to the added abuse in these situations. The stiffer valving in these shocks will strengthen your ride.
+ 150 psi pressurized nitrogen gas
+ 14 mm piston rod
If you would like to upgrade to nitrogen shocks,
please note upgrade request in your order.
