seriouse help
mudfinder
i just got my 91 path lifted with AC's 3inch suspension lift, after getting lifted the truck viberates from 0-20mph after 20 it's fine. i was told that a drive shaft pin kit should of came with my lift kit to correct the angle of the drive shaft. if anyone knows what taking about please help. :sniff:
You need an alignment after you put a lift on. But I would think it would do it at all speeds. Make sure your front end parts are all tight and also, i know it may sounds stupid but i have seen it twice before, check your rims and make sure the lugs are tightened good. If not it will cause the problem you are experiencing.
3 inches of lift won't cause driveshaft vibration as far as I know. Your rear u-joints might be going on you. Check for looseness or play in the rear driveshaft. Also check clearance between the driveshaft and the safety hoop in the back. Don't let the driveshaft rub that thing...
