2003 Pathfinder purchase questions
rovergirl
Ok one more thing. I noticed when I put in a cd I have the option to input album and track information. Anyone know how I do this? I have checked the manual but it doesnt seem to give any information.
congrats on your purchase! if it's anything like the bose cd changer in our maxima, i believe it's the PYT button (not too sure, haven't rode in it for a while) that toggles between displaying the track title, disc title, or artist name ONLY IF the CD has cdtext, you can burn cd's with this option with no problem on current cd burners. but as far as cd's with no text info, i'm not sure if you could enter it manually through the stereo interface...but if it could, i'm sure it would be a pain =P hopefully someone finds out for you.
EDIT: as for your tire issue, i noticed a HUGE difference from the stock bridgestones to all terrains...more of a crisp and controlled ride, especially over bumps, holes, and while turning. i found the stock bridgestones to be too soft and mushy 'causing a slow repetitive bouncing when going over bumps, and excessive tire roll in turns.
Edited by QuismO
i use NERO which came with my burner, i believe it's the last, or 2nd to last step where there's a check box to enable cd text (it'll pull info from the mp3 info tags or straight from the file name if it's in the "artistname - songtitle.mp3" format). i know that ROXIO and the older adaptec cd burning programs have this option...most, if not ALL of the new software have this option standard.
