How to review the O2 Sensor ?
WRL69
review?.....it's not a computer sensor or anything that you can review...if that's what you mean, but you can just read up on where it is located and take it out with a wrench.....it's really looks more like a valve of some sort. Very easy to replace. If you do a quick diagnostic it will let u know if it's bad.(if u can get it checked cheap) it is located on the driver side. There are tons of answers for you if you'll check the top right
corner of the page....SEARCH....then type in oxygen sensor....I'm sure that should help you.
Edited by govols74n
