Time to weld my frame
MikeV
I just lifted my Pathy and while "operating" I noticed what 250,000 miles of Wisconsin salted roads had rusted long holes in my frame(above rear axle that was behind wheels).
I have read and searched the forum, but not much actual info on repairing.
I glanced at the few frames at the local junkyards and they were MUCH worse. And retiring my beast before half a million miles is not an option! :Magic:
I am going to weld the rusted frame as it is in a few spots I am going to purchase a new welder (figure I would spend more having someone else do it (and I have welded my 70 & 71 240Z's front ends together and that "uni-frame" was the thickness of a pepsi can)).
I have por-15 and am cleaning the inside of the frame with air(120-150psi) and an air fitting with 3 feet of bendable copper tubing(think liposuction vacuum) :oops:
I am running it in the inside to get rid of the pounds of rust, sand, mud...
Questions I have: :confused:
1. I am wanting to treat the interior of the frame with rust treatment.
(if I flood it with por-15 it will cost a bajillion) I am using por-15 on the external parts of the frame) any other treatment recommendations would be appreciated.
Note: I need to weld plating over the existing metal
2. looking at buying a new welder, $400-$600 range, 120v, optional gas, wire fed.
Just wondering what everyone uses? (I love this excuse to get a new welder!!! :cool2:
3. Any don't forget to's would be awesome (as in take the gas tank off...!)
I will be documenting and posting pics soon.
Thanks Again!
:beer:
Lincoln SP-135 is the bare minimum I would want to own. And I do! It does a fine job for a home unit.
Realistically, will NOT do anything over 1/8", but that should do your frame. Maybe 3/16" with flux core wire.
Do the rust treatment after welding.
Coating the inside of the frame is difficult... Spraying through any holes with a high volume, fine mist will tend to fill the frame full of fog that will coat a lot of it... but it won't get it all and will make a mess....
And just so you know, both the '87 and '88 I bought here in CA were effectively rust free - so you may want to consider importing a blown autotragic from out west...
Just so you know, that is a "dumbed" down version with some questionable compromises to meet a price point. It does not have the adjustability,control, or durability of the real SP-135. And Home Depot does not offer the world's greatest support and repair.... In fact, none!
I strongly suggest you go to a welding store and talk to them first.
You're welcome. Not trying to tell you what you need or should buy, but want you to get a unit you'll be happy with. Ask the pro's about the differences between the SP and HD special and decide for yourself.
If you don't have a local Lincoln dealer, Miller and Robart also make very nice entry level 115 volt units. I consider them all about equals.
