2002 nissan pathy Oil & Fluid charts
NWT87PATHY
see my buddie has a 02 pathy Chillkoot edtion and it was in a flood, we only did an oil chage but now that the winters comming and we found water in the diffs we need to know all the fluid and Oil charts for this SUV but i havent had any luck with finding them, Please Help! :confused: :help:
Edited by NWT87PATHY
Service Advisor gave me this info:
for the front diff, we use Penzoil Gearplus GL-5 for limited slip diffs, 80W90 weight. You can use this in the front diff as well, or just use regular 80W90 gear oil. Rear takes 2.5 litres and the front takes about 2 litres or less.
mmm... not sure if that is different if you dont have LSD.
A non-LSD Diff will be fine with gear oil with LSD Additive in it. Actually, most differential oils you find on the shelf have the LSD Additive anyways. You absolutely want to use GL-5 in the diffs, but NEVER in a Nissan Manual Transmission, it'll eat all of the brass fittings and seals faster than you can say, "Oh damn, I f***ed up!"
