Dashboard brake and battery light
Guest jbpathy
Guest jbpathy
Just changed my front/rear brakes and installed new battery on my 94 se pathy...cant get the darn dashboard brake(not abs) and batter light off. I have reset the ecu(no trouble codes)....Anyone have ideas???? :furious:
I take it the light is on when running? check your charging system and make sure your alternator is working correctly. A loose battery connection may be causing you some problems. Also, since you just changed brakes, double check the master cylinder level sensor(if you have one).
