Difference in auto and manual
unccpathfinder
ok im working with a 95 harness that was auto and im going to manual...what im missing are the 2 switches for the clutch 1 at the bottom of the stroke (assuming start ok sensor) and the 1 at the top (assuming this is disengage cruise). but my 87 doesnt have cruise and it has a sensor on the top and bottom of the clutch stroke...
:wacko:
i started taking the harness apart and looking at my 95 manual and the auto harness and noticed that it had a red w/green line wire connecting to the start up sensor so i pulled a lot of the harness apart hoping to find the plug with a jumper which i didnt find...
what i did find is that the red wire has a jumper over to another red wire and im assuming this bypasses that switch...any1 have any clues?
guys that did a auto to manual swap did you have to include the wires for the clutch sensor and if so was the plug there or did you have to splice in?
