Has anyone?
cdhicks99
I am considering doing this, but I've never been into a chunk before and I have no idea where to get the extra clutches.
I read a write up on this, but would like someone elses opinion on how long this may take and the amount of care needed to do so.
Where does one find these clutches?
TIA
gotta buy them from nissan. i used the 1.5's, which is the middle one out of 1.4, 1.5, and 1.6. its alittle better when both tires are on the ground and chirps if i give it a little gas around corners :D . but even if you lift a rear tire, it will still break loose. sometime i can give it a little brake and it will sorta work out, but its going to be nothing like the detroit im putting in the back soon! :beer:
Just swap the whole 3rds provided the R&P are the same.
That's the easiest, you'll be able to find someone with an open rear who wants an LSD for free pretty easily. I'm sure you could work up a straight up trade, 3rd for 3rd.
