GAS
Everything posted by GAS
hi all Still sturgling whit the gas milage, I did fill it up whit gas yesterday and 65 Liters went on the tank and the km was only 263 then it is almost 25 L/100KM in city driving in only rear wheel drive it is around minus 5 -7 here now on the selcius scale. What I have done to tray to fix this: New spark plugs K&N filter New Oxygen sensor the truck is just stock on 30" tires and have 176.000 km on it. This is automatic V6 3.0L engine model1990 Does it help to take out the catalyst converter and put just pipe insted ? There is no law in Iceland that tells you to have it in, if the car is older than 1995 Any ideas what to do ?
Folks from Australia, New Zealand, Iceland, Japan:
GAS replied to 88pathoffroad's topic in General Forums
hi There is no problem buying for you all cleer lights here, BUT all parts here are exspencive and I think shipping from her is too. If you all like I can look into it for you. Please send me e-mail and I can go to the post office and they tell me the shipping. gas@centrum.is -
Sending unit ? Are that the float in the gastank ? If not where are the sending unit
It is 1990 The temp gauge is ok. Where is this voltage regulator ?
Hi all nice that the forum is back. The petrol gauge is acting strange, when the needle is on E the gas tank is about half not empty. Any ideas is it the float in the tank or is it the meater in the dash board ?
Hi I did run the ECU test http://www.nissanpathfinders.net/forum/index.php?showtopic=21 And I did get CODE 55 that is 5 red and 5 green blinks That is: 55 No Malfunction.
HI you all. I have cleared the ECU off errors shall i leave the control screw on the ON posision after I have turned the ignition key off? The scrwe was in the middle between ON and DIAGNOSTICS when I saw it first and before I cleared the codes. I do not dear to turn the engine on before I know where the scrwe should be. Pleace help the ICEMAN. GAS
Thanks, I will look under the passangerseat and do this. I think I have to remove the seat right ?
Thanks, how is that done ? I don´t find it here in search
Hi Finaly I have replased the OS do I have to reset the computer ? If so how do I do it, is disconecting the battery for 15 minutes enough ? GAS
Hi you all and merry x-mas. I am driving the Patty in rather deep snow this morning, and the light in the power/economy light came on when it was strugling trhue the snow. But went off when I was trhue the deepest snow Any ideas ? Sorry about the spelling
Well, it is the alternator i went to garage and they put digital meter on the battery. Anyone know about chep alternator that would be so nice and ship to Iceland ? BTW here is snowing hevely about one meter thick snow and outside is blissard at the moment. Take care everyone during the hollidays and merry x-mas to you all. GAS
ok thanks Then the alternator is bad it only reads about 12 volts in driving And less at idle bommer
Hi The voltmeter in the car, what is the normal possition for the needle in driving 14volts or less/more ? And when the engine is idling ?
Great news, it worked perfectly I have instelled the vires Thanks for the help
Thnks mate. What is inside this box ? I am going to do this and hope the best.
Hi there The never ending stoy continues The conector for the fusible link broke off here is picture http://img41.exs.cx/img41/1354/1242500img1en.jpg It is very exspencive to order tis here in Iceland. Is it ok to put plugs on the wires and trow the black box avay ? Please help, the car is not running @ the moment once again hehe Best regards from the snow and ice GAS
Yes it is all stock only 30" tires. And I have 178.000km on it
Hi Thanks for all your respond. BUT !! I think that about 6 MPG in city driving just on slippery streets. I would not be complaning if it was knee deep snow This is too much. On highway driving just in rear drive at 56 mph it is around 10 MPG This is too much GAS
well I did heve hole in the gas pipe that goes to the engine and I was not surpriced about the bad fuel milage. But now it is fixed and still this bad fuel milage I am going to look on the PCV valve and OS replasement. Hope it helps. Thanks alot for this
Hi you all I am proud owner of 1990 Pathfinder and it is V6 and automatic. It have new spark plugs and tune allso K&N. I am getting 132 km of 40,5 liters of gas !!!!! I think something is wrong here this is in town driving in 50% rear and 50% 4X4. I think I have to buy gas station or maby they vill give it to me since the x-mas is near Any ideas ?
Thanks mate I have send you mail Here is snowing hevely at the moment
Thanks alot mate. This I think is the case : Revolution sensor circuit is short-circuited or disconnected. Because the first blink is litle longer on than the rest. But now it is time to find this sensor Best regards from the snow
