91rtstealth
    93 se v6...177k...runs fine, leaky water pump, and headlight issues..bought it for 300 dollars!!!
    Screwdriver Mechanic
    Choose
    Choose
91rtstealth's Achievements
  1. i didn't even think to look at the license plate lights...i don't know if they work really.. as far as the fogs go..i haven't even gotten there yet...the headlights were my first concern...next thing i'm gonna do is work on the turn signals..at least then I can get it inspected...i might not even fix the fogs..unless I get bored..hah..however, my fog light switch does not like up, but the relay does click...that's as far as I got...
  2. bada-bing...it was the light switch...i took it apart, pressed on the terminals and the lights would come on then... i just tapped a trigger for low and high beam from the passenger side head light harness and put 2 relays in....the harness gets 12 v, but hardly gets current...but it's enough to trigger the relay.... gonna get a few switches from the junk yard to fix it right...cuz who knows how long til the switch craps out completely... thanks everyone... now just gotta get the fogs and turn signals working...
  3. yeah..i checked the fog relay..it clicks..i'm going to replace it anyways since it's only a bosch relay...i have tons of them laying around.. it's funny that many people on here use the relay to re-wire the headlights..i was thinking of doing the exact same thing, but I didn't know if it would work since wires at the headlights barely have enough current to light up a test light...however, it doesn't take much current to trigger a relay, so i'll probably end up trying that first...seems easy enough since the battery is right there...i'll just use one relay for high and one relay for low beam....but first i'm gonna check that switch out..the leads are probably full of crap... question though..will i find the same wire colors at the switch as the ones at the light bulb harnesses? if it's that easy, i my as well run new wires straight to the lights from the switch...
  4. yeah...i will do that first...is it likely that the light switch could also be causing the fogs to not work right as well?
  5. yeah..i did some research after I posted my topic and realized this...this makes sense why I wasn't hearing any relays..haha...that's a really dumb design...it's no wonder that a common problem with these vehicles is corroded wires and light switch prongs.....so....what you're saying is that I could simply go to the light switch in the steering column...and find 4 separate wires (low beam driver side, high beam driver side, low beam passenger, high beam passenger) and simply run new wires....also, would they be the same color as the wires at the light harnesses? that would be much easier if they were..hah..
  6. ok..i just got a hold of a 1993 pathfinder with a few problems...here is what I am working with... The only lights that work on the front of the car are the passenger side low beam, and both the drivers and passenger side markers.... so..lights that do not work: driver's low and high beam, passenger high beam, both turn signals and both fog lamps... so far this is what I have concluded... TURN SIGNALS: I believe the turn signals do not work because the assemblies are completely rusted, therefor I don't think the light bulbs are making contact with the terminals...I am getting a ground and pulsing 12v at each lights...i have an old nissan pickup with the same lights...i'm going to pop one of them in there to see if it works...now....the only turn signals are the ones in the bumper, right? Or are the side markets supposed to blink as well? HEAD LAMPS: The Driver's side lamp is getting a ground, and 12v for high, and 12v for low...however, I can only get 12v on a volt meter...with a test light, the light bulb in the test light BARELY lights up which leads me to believe it is a current issue, not voltage...i don't think there is enough current to light up the actual head lamp... now for the passenger side...the low beam works...i'm getting a ground, 12v for lowbeam, and 8v for high...has anyone had any problems like this? It seems to me like wire corrosion or something...also, could it be a relay? I can't seem to hear any relays clicking for the low or high beams...and I have NO clue where any of them would be since I can't hear them...any ideas? where are the relays? are there any common wire corrosion areas in these trucks? FOG LAMPS: I have no idea what's up with them..and i'm not real concerned about them..unless they are the culprit to this problem... any clue as to what the heck is goin on here? hah..
