Mihi
    1994 Nissan Pathfinder V6 3.0 5-Speed Manual 4X4 BLACK
    Flagstaff, Arizona USA
Mihi's Achievements
  1. I may have found a solution i found this on another forum any insight would be appreciated "Hello, I had the same problem on my 95' with the tail lights not coming on with the headlights or shutting off when driving (great no one could see me from behind). It's the turnsignal-headlight switch. I fixed this easly in 30 minutes. Underneath the steering wheel remove the 4 screws that hold the bottom half of the steering wheel bezel. Once you have those off you can lift the top half of the bezel a bit to get to the two screws that hold the switch in place. Remove switch and take inside your home / or shop. There is a plastic plate that covers the where the contacts are. That plate is about a 1 1/2" roughly square. I forget if it has screws or not , unscrew and or pry to pop that piece of plastic off. You will now see 4 or five contact legs. One for the headlamps 1 for taillamps and 2 turnsiganl contact legs. From turning headlights on/off alot they get unsprung a bit and will make little contact with the other mating surface. I used a small screw driver to bend them towards the inside of the switch so they could make good contact. Take the switch in your hand and turn it on , you will see a one or two legs that have lost some off the orginal bend to make contact (thats the brake lights, use a small screw driver or you thumb to bend then inwards a bit to match the other legs. You could also use a very small pair of needle nose to bend the legs downword towards the other mating surface. My tail lights worked after this fix and i haven't had a problem in the year that i did this fix. good luck it works! Take your time to understand where and how the contact legs go to make a connection." i'm headed out now to try it
  2. I have a 94 and i am having an electrical problem my tail lights(not brake lights), instrument cluster backlight, and air conditioner controls backlight are not coming on with the headlights its not a fuse(as far as i can tell) and i know its not the bulbs because all said lights blink when the alarm is activated/deactivated what could this problem be and how can i fix it to avoid paying for it in the shop?
