Nascat
Everything posted by Nascat
  1. Hey guys thanks fore the help. I was bout to head to the auto salvage yard and just be fore I left I tried to clean the plugs ins again and spray some cleaner in side the amplifier. Well that fixed it. Yep working fine now.
  2. Thanks for you input Rob. I found a free down loadable 95 service manual that has the diagram you speak of. Your right not a lot of help. Is the wiper amplifier, the box that I described as being mounted on the wiper motor, or is it located else where? Makes a lot sense that there would be a wiper amplifier and its not responding to the wiper switch. Will look for one Monday. Besides Dealerships and pick a part, are there any other resonably priced places to also look for it? Thanks again Guys.
  3. Yeah, Thanks for the input, I plan to isolate and test the circuit, disconnect the stereo, check other connectors, etc... The cruise control lights up some times and not other times, so I am just at the beginning of seek and search. Tested the driver door power lock switch, no power to switch. Will get sometime this week to work on it and post later.
  4. I just bought a 95 Pathfinder XE 4X4. It rained the other day and the wipers would not work. After checking fuse under the Dash (good). I put a little rap on the light brown box mounted on the wiper motor and they began an inter mitten wipe but would not shut off at wiper switch. So I up-plugged the connector right at the wiper motor. It was full of corrosion. Clean it out and plugged it back up. Still the wipers would not shut off or respond to a different speed setting at the wiper switch. I went to a local Nissan dealer parts department and he was unable to find wiper relay, wiper control unit (without part numbers), other fuse and relay locations or show an exploded view, give a location of parts on the car, in another words very un-helpful to say the least. Thanks for the help. P.S. - The previous owner said the door locks stop working after he installed a stereo. I wonder if he may have messed up the ground?
