I bought a 94 Pathfinder for my 19 year old daughter here in CT, as she is going to spend the Summer working in SC, and will take this car with her. She will be a long way from home, so I want to go through the vehicle before she leaves in mid May, and so I have some questions. This vehicle has the 3.0 engine, with an automatic tranny. I am going to change all the fluids, filters, and various wear items before she goes. According to Carfax, the timing belt was done at 63,000 miles, and the vehicle now apparently has 71,000 miles on it.
Here is some basic info on this vehicle from Carfax--
Year/Make/Model: 1994 Nissan Pathfinder LE/SE/XE
Body Style: 4 DR. WAGON/SPORT UTILITY
Engine: 3.0L V6 EFI SOHC
Fuel: GASOLINE
Driveling: 4 WHEEL DRIVE
Manufactured in: JAPAN
Safety Equipment: Rear Wheel ABS, Active (manual) belts
Standard Equipment: Power Windows Optional, Power Steering, Air Conditioning Optional, AM / FM Cassette, Power Brakes, Tilt Wheel
I have no prior knowledge of Pathfinders, and this vehicle has no owner's manual
My questions are:
Tranny fluid - Some vehicles are very fussy about using OEM automatic tranny fluid - Is the 94 Pathfinder OK with non-OEM fluid, and if yes, what spec does it require, and what is the quantity needed when I change the fluid and filter? I'm OK with buying OEM fluid & filter if required. We have a Nissan dealer in the neighborhood.
Transfer case - what oil spec is required, and how much?
Rear end - what oil spec, and how much?
I will likely go with Mobil products for the rear end and transfer case, as I have a barrel of Mobil Synthetic transmission / rear end oil for my trucks in our garage.
Coolant - is this Pathfinder fussy about OEM coolant? Some vehicles are, due to specific additive packages. What is the coolant capacity, as I want to flush the cooling system and install a new thermostat & gasket.
I am of a mind that aftermarket name brand parts are OK for the belts, hoses, plugs, PCV, fuel filter, air cleaner, and so on. Please correct me if I'm wrong.
Please let me know what else I can do to put her in a reliable vehicle.
Thanks
