davidcar
    1993 2.7 TD Terrano, 12psi boost, K&N air filter
davidcar's Achievements
  1. Thanks all for your advice. I did it without pulling any CV's completely out of the spindle...just pulled the hub and snap ring, etc. While I was in there I repacked the CV joints and wheel bearings as well. Anything hard about removing upper control arm bushes, (do they need pressing out??)
  2. I did some seaching and it appears that I have to remove the wheel hub from the rotor. There is an area where the CV boot attach's near to the rotor and this is what is stoping me getting the ball joint out, would it be the back of the wheel hub?
  3. Hi all, can anyone explain the process to replace lower ball joints on a 1993 terrano/pathfinder. I went to replace my lower ball joints and it looks loke I have to remove the entire setup to get the ball joint out?? HELP how do I do this??
  4. thanks for the write up, I re-indexed mine today, it was very easy following your instructions, thanks
