MJBBMANO
    1997 LE
    Do Not Go Off-Road
    Florida
MJBBMANO's Achievements
NPORA Regular (2/5)
  1. That sucks! My mechanic wants to charge me $18. Is it worth the $18?
  2. I have a 1997 LE and the fog light bulb burned out. I purchase the bulbs but I don't know how to change them. can anyone tell me how I to do it? I've changed my headlights and taillights but i can't figure out how to do this with the fog lights. Thanks
  3. Its says that they should be gapped at .044
  4. Thanks for the info. It looks like the wires are setup correctly. The plugs I put are NGK BKR5ES-11.
  5. I don't know how the valuetrain would sound or where it is. It only happens as mentioned before. I've had this problem for at least 2 years now. When I change the spark plugs it's a bit less. Any idea what it can be?
  6. It has a little knocking when I go in reverse slowly coming out of the garage and when I'm in drive and have the brake applied. Even more when the A/C is on and I'm at a stand still in drive. I thought it was the plugs so i changed them. I also notice the mechanic who did the tuneup last never gapped the plugs. I gapped the new ones I just put in.
  7. I changed my spark plugs today (NGK regular). I also replaced the wires with NGK wires. The ones I had were very cheap and broke when I was changing the spark plugs. I was looking at the wires and I feel that the mechanic who did the last tuneup put them out of order. Is there any diagram out there that would show me where each wire should go?
  8. My A/C compressor finally died. I only get hot air coming out now.
  9. Is this something I can change myself? the only exp I have is changing oil and spark plugs. Would I need any special tools?
  10. thanks for the info. I made it to Tampa and back.
  11. Thanks for the replies. My A/C still cools the same. The only thing is that when I put the blower switch to "2" its very low like "1". When I put it at "3" its like being on "2". Like I said earlier its been doing this for 3 years. When I put a new compressor in that compressor will also have a clutch? Does anyone know the part number or part name I need? I have seen some that say clutch or no clutch. Are there any other parts I need to change that are part of the compressor? So I'm ok ok to drive to Tampa and back. (65-70 miles each way). Thanks again.....
  12. I added freon like 2 months ago but it wasn't that. When I turn the A/C on you hear a loud click. I really don't know what the clutch is. Is it something I can find? Thanks
  13. My A/C compressor has been making noise now for at least 2 years. Sometimes when the cold air isn't coming out I have to Press the A/C button a few times and it kicks in. My question is, If the A/C compressor stops working all together will it cause my truck to turn off while driving or not turn on at all? I'm driving this week to Tampa which is about 60 miles and don't want to get stuck. I have a 1997 Pathfinder LE. Thanks in advance!
  14. LOL!!! I think I meant hose. I'll have them connect the computer again.
  15. Ok its now been a bit over a month and the noise never came back. I'm going to have believe they never put enough oil in it.
