inca
    1999 Model
    Screwdriver Mechanic
    Choose
    Choose
inca's Achievements
  1. The air, fuel and oil filters are all newly replaced. Also new engine oil.
  2. I have a problem with my Terrano R3m-V ( Pathfinder? ) R50 Chassis with ZD30 DDTi engine. I am living at 3000mtrs above sea level. The motor is very sluggish. I was pointed in the direction of maf failure, which was indeed the case. I have now fitted a new maf, which is working normally ( 1.7 volts at idle, 2.8 volts at 2,500 revs and over 3volts at 4,000 revs ). The motor is running very slightly better, but still very sluggish. The engine revs no problem but lacks power. Any further hints where to look for continuing fault. The mechanic in the garage took out the oil dipstick while the engine was running and said there is very little compression. Heeeelp.
