cretan
Everything posted by cretan
  1. Was under the truck today and it looked very difficult to remove.Your reply makes it sound easy to do.thanks for the Tip!!
  2. I have a 94 xe v6 5 speed.How difficult is it to remove the starter?
  3. Thanks for trhe info 95shakinPFI have not had time to check vss or speedo yet.Will post findings when i remove the parts.
  4. will look out for those things you suggested.thanks for the help.
  5. thinking of buying a 97 infinity q4.Are these reliable vehicles?Are there any issues with these models?
  6. Thanks for the replies!Sometimes it would run fine then other times it would bog and stumble.Changed the o2 sensor=Engine light is now off and engine runs awesome.Glad the knock sensor is fine cause I priced it out and it was between $350 and $450 bucks at the parts store.
  7. got code 33 and 34.will changing the o sensor fix the problem?
  8. The speedo on my 94 pathfinder doesn't work until I go over 20 kilometers an hour.sometimes it quits al-together.Is it cable driven or electronic?Any suggestions on what would cause this?
  9. I just bought a 94 pathfinder.The day after I bought it the engine light came on and stays on.How can I check the codes?On my toyota I connect a wire to a connector under the hood and watch the light flash on the dash for the codes.Are the nissans the same?
