Tincan4X4
Everything posted by Tincan4X4
1990 Pathfinder Calmini 3" coils and drop bracket Possibly some spring pads for a little extra cushion/lift No swaybar Should I run 99116 shocks(1.5-3" lifts) or should I run the longer 99112(4"-6" lifts)? Thanks.
Getting ready to get some new wheels/tires. What size lug nuts do I need to get for a 1990 PF?
Guiness to thick for me. Ill take a Newcastle, thanks.
I have been member to some pretty nazi like forums, but its pretty kick back here.
Since JGC coils work, will these work with PF coils? http://rustysoffroad.com/mm5/merchant.mvc?...gory_Code=COILS Uerothane spacers for the grand cherokee. 1 of these on each side of a 3" PF lift coil would be sufficient I think.
Holy crap, thats alot of lift trailchaser. I have a 3" body lift on mine, if I use those springs Id look like a mini monster truck. LOL.
I am in SoCal. No such thing as a "rare" import here, other than an R34, only seen a few of those. I have always liked how the Imprezas handle, even back to the 2.5 RS(96-2001). The Mitsus 4G63 blows ass.
How much rear lift did that give you?
There are only 3 choices that I have been able to find- Calmini, 4x4parts(AC), or the JGC spring mod. Are there any others out there?
Subaru STI
Worst case is they break and you lose steering. I wouldnt wait to fix.
I wonder if this is the cause of my transmission moving back and forth under acceleration/deceleration. I checked the motor mounts and trans mount and everything seemed peachy. Maybe my rear link bushings are bad. And I also get a nasty clunk from the rear once in a awhile as well. Maybe I found the cause of both problems.
I need to remove my rear links from the suspension to take some measurements. Whats the easiest way of doing this? Is it as simple as jacking up the rear axle housing a bit and just unbolting the links? Also, anyone happen to know the torque for the link bolts(frame side and axle side)? Thanks.
Word, got mine as well. Put them on the next day.
Where can you get just the arms? All I can find are complete kits for the hardbody. And they are just 1.5-2" lifts, so I guess the extra lift is from tweeking the torsion bars?
Question for the Mechanically inclined with Pathys...about tools
Tincan4X4 replied to NaturaTek's topic in General Forums
And a few steel pipes in various lengths. For when a breaker bar alone is not enough. LOL. I have a 5 footer for breaking axle nuts. -
I started out with one of those large Craftmans sets and just built up from there. -
Thanks.
I was looking at ARB air lockers for my pathfinder and they have 2 for the H233B, for 31 spline and 33 spline, is there an easy way to tell which you have?
Hmm, thats the same paypal address for the ones I ordered. Pretty sure I ordered them from the stickied thread. Yup, the link in the sticy thread took me here which is where I ordered mine- http://finishlinegraphics.com/cart/index.p...at&catId=32 I still havnt gotten mine, but its only been a week.
Well it would have been more complicated than simply bolting the carrier and tire directly to the roof. I knew Id have to spread the load(I did have ideas for this) and I was hoping that the roof was pretty strong to begin with, but I guess thats not the case. Looks like I will need to run some sort of rack. Hey 88, just noticed you are from Salem. I have family there. I havnt been up to Oregon in years.
Is there anything out there that will allow for mounting the spare on the roof without the use of a rack? I have found some things that "might" work, but just want to see if there is anything I missed. If I cant find anything I will just cut the spare mount off the rear swing rack, modify it and bolt it to the roof.
Look good, just ordered a couple of the reflective white.
Thanks, is there a website for Hoohaa? Ill check it out.
