german996
Everything posted by german996
Hi there, just received them, and lready installed, looks bitching, german996
LD50 , how much was your CL, I google it but could not find anything, just to be prepared and aware of the cost... thanks German996
hi again, I guess that i will try the new methods, and let you guys know, thanks German996
I lift the front end , and did not feel any freeplay at all in the tires, thanks for the info
Hi everyone, I have been learning a lot about my PF through this forum I think is awesome, I have a 95 at tranny, 4wd, that I have just started off roading with , and I am concern with th e center link and also with rust in the frame, I show no signs of it yet, maybe I never will , but is there a pattern in early wear in the CL or in the frame on this rusting issue? thank you once more for your help and opinions
Hi everyone, just reorder a second set of decals , still dont know what went wrong with the last order, just hope I can get them before January.. regards German996
95shakinPF, Hi there, if for any reason you still have the functioning tach that you are selling let me Know, I need it for my 95 pathy.... thanks German996@yahoo.com
will check the grounds and connections for each horn, I have already check the ones in the steering wheel, thanks, german996
Hi Darren, if you look in search section you will find that part number 14065-v5004 is the revised exhaust manifold studs, basically from the nissan 300 zx twin turbo, they cost around 8 us dollars.. regrds German96
my horn works intermitently, dont know if there is a bad contact in the steering wheel , I tried to take it apart and the lower part seems to be stuck and I didnt want to force it, so I squeez a file to clean the contacts , but no luck , I know the horn is located behind the front bumper inside the wheelwell, ( between the tire and the bumper) , have anyone had any trouble with the horn? german996
aux. driving lights installation question
german996 replied to german996's topic in 90-95 WD21 Pathfinders
Oficially the installation can be done without removing the bumper , accesing by removing the aux light panel and lights as LD50 said, it was a very smooth procces and easy acces with a ratchet and a 17 mm deep wall socket, the painfull part was to run the wires from the engine compartment into the dash area, but it is now all done, thank you for your suggestions.... German996 -
sorry , did not read the whole thing,,, german996
hi guys, it happened to me too, I ordered club decals from this guy Firerescue... , over three weeks ago and havent got anything, I did folloe the link from the NPORA website... any clue? maybe we got framed, will have to order them again? regards German
well , It has that ticking noise since day one (2 YEARS AGO), BUT i thought it was an exhaust leak due to a leakey exhaust gasket, like every other nissan maxima that I have heard, I am a motorcycle tech for GP motorcycles in San Diego (Italian motorcycles), but it was not until I joined npora that I got curious about the noise and decided yesterday to remove the heat shield and dyscover the problem to be a broken stud, I have to confess that I am totally intimidated on working in my PF, got use to just working in motorcycles for the last ten years...and that spoiled me. regards' German996
I was saving up some money to do the timing belt and other more important stuff, like water pump, pulleys, belts and hoses... german
Wow, what I was afraid of just happenned, one broken stud and one loose nut (me), my PF is not lifted, I will replace the existing studs with the nissan 300 ones, my question is if anybody without the lift kit had already replaced them through the wheel well , or because mine is not lifted I will have trouble doing it?, what a bummer, mine is automatic also, it has been ticking since day one (2 years ago) , and today removed the shield and found the little surprise. Are we only having problems with the passenger side only , or the driver side will eventually brake?, can I keep driving the thing ?my only transportation. regards German996
Hey TD50, that sounds even better, will definetly try to do it that way this weekend, thank you for your idea... german996 -
thanks Josh, will do. -
u r the man , that was so quick, German996 -
I was afraid of that answer, u happen to know the size of the nuts by any chance , like by heart, thanks for ur help, German996 -
Hi there, just wanted to know if to install the auxilary driving lights on top of the front bumper, the bumper itself has to be taken off , or if you can measure and drill just taking the grill off and tighten the bracket mount from behind? any help or suggestion will be deeply appreciated german996
Thank you for your guidance,very helpfull, will try out tonight.... german996
Hi everybody, my temp gauge was very bouncy and my tach was working fine, in my 95 PF a/t, now they switch after the Pf was garaged for a while, now the temp gauge works perfect and the tach barely woks, which make me believe taht there should be a ground issue, so to remove the cluster from the dash after removing the two top philips screws what else need to como off in order to remove it? I already did a search and went to the HOW TO section. thanks for any help or guidance in this matter, also would like to change my bumpers from chrome to black , any suggestion in this matter? thanks German996
Hi all, just wondering where can i order a NPORA decal that goes on the top of the front windshield? also trying to get my PF up to date in things that i have been neglecting, and probably will need your technical advice in some procedures, thank you for help in advance german996
Is definetly automatic transmission, it will get a full service this coming week, have a good one
