03R50
Everything posted by 03R50
  1. Go ahead and buy new valve covers and save yourself the trouble of leaking spark plug tube seals. The stock seals are not really replaceable. I used some red aluminum valve covers from a 350z off Amazon and modified the valve covers to fit. These valve covers have east to replace tube seals. I started by plugging the breather tube on the left valve cover with quick steel, then drill and tap for a fitting on the top for the breather line. For the right side I cut the middle harness brace off the right side and used a generic Dorman 3/8” 90* rubber pcv elbow for the pcv. Here is the link for the valve covers MITZONE Upgrade Aluminum Valve Covers Left and Right Compatible with 2003-2008 Nissan 350Z Infiniti FX35 G35 M35 VQ35DE 3.5L Part # 13264AM600 13264AM610 https://a.co/d/4ErRHj5
  2. I am new to pathfinders. I have a question about the pcm. I am looking to add a power trunk actuator to pop the hatch glass using the factory remote fob with 4 buttons. I also want to add dual 2 speed fans controlled by the pcm. I am not sure if these actions would need to be turned on with a consult easily or if the pcm is even capable of these actions.
